Help replacing bathroom exhaust fan on plaster wall
Old 07-08-16, 07:09 AM
F
Hello everyone,
I'm replacing my bathroom fan on a plaster wall for a slightly bigger one so I have to open the hole up maybe another half inch all around.
Can I get this done without getting into plaster work? Are there fasteners I could use on the existing plaster to hold the new housing in to make this work?
Thanks in advance!
Flavio
Old 07-08-16, 07:41 AM
Received 98 Votes on 86 Posts
Welcome to the forums.
I'm not understanding - you need a bigger hole, how is some kind of fastener going to solve that problem for you?
Old 07-08-16, 08:27 AM
F
Sorry stickshift. I wasn't clear. It's 2 separate things. First I have to open the hole a bit. Then I have to get the housing to sit in there. The fastener question has to do with fixing the housing in there after the hole is big enough.
Old 07-08-16, 10:25 AM
Ah, I get it now. Hang tight, I know someone will have an answer for you shortly.
Old 07-08-16, 03:27 PM
Received 99 Votes on 87 Posts
Is that fan even rated to be wall mounted, looks like a ceiling mount to me.
That style is made to be nailed or screwed to soild wood.
What's the plan on connecting it up to the exhaust hose?
A Roto Zip with a tile bit or a 4-1/2" right angle grinder with a diamond wheel will open it up 1/4 on each side.
Old 07-09-16, 08:07 AM
F
Thanks joecaption.
The fan is designed for wall or ceiling. There is a duct inside the wall that connects to the shaft that vents out the top of the building. The fan comes with a plastic duct that will connect to that.
I don't know how to fix the fan to the wall opening. I think previsously someone just plastered the previous fan into place. I don't know if I need to build a wood frame in there somehow or if I can use special fasteners to hold it to the plaster that is there already.
Old 07-12-16, 05:23 PM
F
Any ideas of how I can attach the fan to this opening? Thanks
Old 07-12-16, 06:02 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
What is at the back of the hole. How far from the wall to the back of the hole?
Old 07-12-16, 06:34 PM
F
Hi ray2047,
There is a pipe and behind that concrete or cinder block.
Old 07-12-16, 06:42 PM
Tolyn Ironhand's Avatar
Received 332 Votes on 286 Posts
After you make you hole the size you need, take some 2x material and screw/glue it to the back side of the plaster on the edges where you want to attach the fan. (power grab or some other construction adhesive works well) Remove the fan from the housing, make your electric and venting connections and put the box in the hole. Screw the housing to the 2x material through the side. You may need to make your own holes.
Old 07-14-16, 11:10 AM
F
Thanks Tolyn, this sounds like a great approach. Going for it!
