Whole house fan in sloped ceiling
Old 08-09-16, 09:13 PM
B
I want to install a whole house fan upstairs but there is only a sloped ceiling in the hallway. I've heard you shouldn't put one here because the loovers wont shut properly, what are my options?
Old 08-09-16, 10:05 PM
Received 3,632 Upvotes on 3,254 Posts
If the hallway ceiling is sloped.... is it because it parallels the roof ?
If yes.... how much room is between the ceiling and the roof sheathing above it ?
Old 08-10-16, 05:56 AM
B
It doesnt parallel the roof, I have a flat attic floor above it. There is about 4 feet between the floor and thr roof sheeting
Old 08-10-16, 06:18 AM
C
Received 135 Upvotes on 111 Posts
How much is it sloped? Can you mount the fan level a little above ceiling level and then box in the opening down to the ceiling? Similar to what would be done for a skylight.
Old 08-10-16, 12:39 PM
B
About 35 degrees, im worried the loovers wont close completely when the fan is off.
Old 08-10-16, 02:12 PM
C
So two ways to go. You can mount the fan level on the attic floor and box in an opening down to your sloped ceiling. The fan would be level, so no issue with it closing.
Or you can use a ducted whole house fan, such as this one: https://www.wholehousefan.com/quiet-cool-2250-classic/
The inlet for that style can be mounted at any angle, even vertically.
