Ventilating 2 rooms, HELP! SEE PLANS ATTACHED
Old 03-07-17, 08:27 AM
B
HOUSE PLANS.pdf
Hey guys. I've got two rooms added to my garage and I need to know how to ventilate these rooms properly. This may already be a proper ventilation, but I know nothing about this. Is there a better idea? The rooms are still under construction so, a hole in the common wall is ok if needed....
Thanks in advance!
Old 03-07-17, 08:33 AM
B
I'm also kind of wondering if I should put a wall vent between the game room and laundry room.
Old 03-07-17, 11:34 AM
airman.1994's Avatar
Received 8 Votes on 8 Posts
Have you looked into a ducted mini split? Id be worried about moisture issues in the laundry room with out conditioning it.
Old 03-07-17, 12:11 PM
B
just looked into this, that'd be out of budget though. So when no air conditioning, I may need to leave the door open to the laundry room -to the garage. Garage usually has open window....
I know that hot air rises, lol thats it. Will the cold air from A/C and hot air from heater travel to the laundry room via ceiling vent effectively. Or would it be better to connect the rooms via wall vent.
Thanks!
Old 03-08-17, 01:45 PM
You will need to have a fan in the duct to at least push air into the laundry room.
