How much CFM do I need?
Old 03-07-17, 10:44 AM
Received 2 Votes on 2 Posts
I'm trying to determine how much CFM I need in a 4" duct in order to achieve a capture velocity of 75 FPM 12" away from the source of pollution (a hot plate). The 4" duct will have a 14" conical hood on the end. I've already calculated the CFM required at the hood face, but need to determine what velocity I need inside the duct to pull this amount of volume at the hood face. Here is what I have thus far, using Q = V (10*x*x+A)
Q, Volume of airflow in CFM
V, Centerline Velocity at X distance from hood in FPM
x, Distance from hood in ft
A, Area of hood opening in ft[SUP]2[/SUP]
For V = 75 FPM (recommended flow for exhausting soldering fumes), x = 12", and A = 1.07 (area of 14" round hood)...
Q = 75(10*1*1 + 1.07)
= 830 CFM
I'm not sure I'll be able to pull this amount of volume, but regardless, if I need 830 CFM at the face of the hood, how much CFM do I need in the 4" duct? I imagine it's a function of the hood opening, the duct opening, and the distance between the two? I'm looking for an equation basically, disregarding any losses.
Old 03-07-17, 11:21 AM
The duct in the building is a 4" round duct, so there's no way we'll be able to get this kind of air flow. What is the maximum CFM we can effectively pull through a 4" duct that is about 40 ft long?
Old 03-07-17, 11:38 AM
airman.1994's Avatar
Received 8 Votes on 8 Posts
depends on the size of your motor and fan. Just put in a 10HP exhaust fan to pull 6000cfm on 8in duct for a fume table.
Old 03-07-17, 11:42 AM
normal cfm on an HVAC system would be about 35cfm
Old 03-07-17, 11:53 AM
Let me rephrase, is there any limitation as to how much volume can be pulled through a 4" duct? I realize the more flow the more losses, but is there any limitation aside from imploding the duct? I'm obviously exaggerating, but I need to know if we need to increase the size of our ductwork or if we can simply beef up the size of our fan.
Old 03-08-17, 01:42 PM
bigger fan will move more air.
