fantec flex 100h operation
Old 12-06-17, 06:39 PM
hopkinsr2's Avatar
Hi All, I have a fantech 100 h HRV & I don't know if I understand the correct way it works.. 1st when I have the humidity set @ 80% on the control, the unit will run all the time even tho the display shows 45% humidity in the house. If I turn it so it is only supposed to run for 20 mins of the hour, when it is off, the display still indicates it is ventelating,, The furnance fan runs constantaly unless it calls for heat.. Should the Ecotouch panel that is on the wall that I ask for 80% humidity not shut the unit down untill it is called on to reduce the humidity??
Thanks, Roger
Old 12-14-17, 05:53 PM
hopkinsr2's Avatar
Any HVAC people out there?? I'm sure im not the only one with a fantec HRV.. Anyone???
Old 12-14-17, 06:00 PM
Received 2,802 Votes on 2,537 Posts
Not real familiar with that system but I will check into it and respond a little later.
Old 01-01-18, 08:39 PM
hopkinsr2's Avatar
Thanks Lots I'll keep a watch for your reply, Right now the outside air is -35F & my inside humidity is 30% with the HRV off.. If I turn it on & comand 80% humidity, it will run until I turn it off??? Does this sound right?? ,, Roger
