Attic smell coming in house vents
Old 07-17-18, 09:56 AM
Stumped
2yrold a/c unit- have been having attic smells so they replaced the intake which had major holes , and they put in Flex ,
At first seemed to solve problem, within next day - back to smelling attic smells again! What else could this come from??
Any suggestions appreciated
Thanks
Old 07-17-18, 03:32 PM
B
Received 37 Votes on 34 Posts
Hi Jimmy and welcome to the forum.
Summer stack effect involves that expensive cool air (its heavier) seeping out the lower leaks of the house and the necessary equivalent amount seeping in the upper leaks. Some of those can be the hvac ducts while others are all over the place, electrical, plumbing, drop ceilings over cabinets, and recessed lights to name a few. I'll add a link on air sealing although it primarily describes winter stack effect, summer just works in reverse.
Bud
https://www.energystar.gov/ia/partne...ide_062507.pdf
Old 07-17-18, 04:29 PM
Thanks Bud- i will check out the link you sent
Old 07-17-18, 04:37 PM
Old 07-22-18, 01:55 PM
Driving me Nuts!!!
Anyone ,Bud- if you read this
i tried everything possible making sure no leaks even after had a/c guys seal up leaks , etc.
And still smelling attic inside house! Gotta be a leak somewhere still - right???
So frustrated and any suggestions would be great.
Thanks
Jimmyd123
Old 07-22-18, 02:12 PM
B
Solving air flow issues in a house requires that we understand what you have for a house.
Slab foundation or basement/crawlspace?
Ranch, 2-story, cape, or other?
Your climate region?
Describe "attic smells". Hot plastic, dead mouse, musty/dusty, sewer gas, give it your best shot.
What else is up there, fans, ac equipment, stored items?
Are there any recessed lights in that ceiling/attic floor?
Pull down stairs, hatch, and how well sealed?
Also, what do you have for attic ventilation, ridge vent, soffit vents, gable vents, other?
Bud
Old 07-22-18, 02:23 PM
Attic smells
When i say " attic smells" its a dusty/ dirt smell best i describe it
actually no good ventalation in attic at all , just some slit openings close to rooftop....
Old 07-22-18, 02:32 PM
Continued on attic smell problem....
Also should mention that i have lived here for almost 7yrs. Now and havent had this issue until this year ,and only change within home is replaced a/ c unit 2yrs ago and this pasr couple weeks replaced the return air ducting systemwith flex , and new elbow put on unit.
go figure-
Now what else is causing this attic/ dusty smell in home???
Anyone with advice - much appreciated.
Old 07-22-18, 02:36 PM
B
If the attic air is not being vented to the outside that would be a good place to start.
And how about all of the other questions??????
Bud
Old 07-22-18, 02:37 PM
XSleeper's Avatar
Received 714 Votes on 661 Posts
Do you replace the filter regularly?
Old 07-22-18, 02:49 PM
Answer to other questions
This is a duplex i live in- and walls are brick
the a/c unit is upon rooftop and the ducting is within attic itself not storage items up in attic, etc. No fans
But this is nothing to do with the issue of smells of attic through vents in home-
Im a retired plummer and been in plenty of attics in my life and know the smell of attic./ dusty dirt smell you may want to call it that....
Old 07-22-18, 03:11 PM
B
Jimmy, you have to put yourself in our shoes as we don't know anything about you or your house until you tell us. Just mentioning that you are a retired plumber changes how we are thinking on this end and i know you understand.
From here I would be air sealing the attic floor per the guidelines within that link I provided. The normal air movement during the summer is cold air escapes the lower levels of the house creating a negative house pressure that draws the attic air in wherever it can find a path. Plumbing, electrical and heating have cut many holes along with drywall against framing which never seals perfectly.
Bud
Old 07-22-18, 05:26 PM
Attic smells continued
Bud - Thankyou for all your input - very much appreciated!
before they replaced the intake on this a/ c-unit because of the attic smell - these guys gave me every excuse other than leaks in the intake i- I decided to go up into attic myself and took a piece of incense and lite it & had my wife stay downstairs & let me know when / if she smelled it - which she did smell it- therefore i knew there were leakI.so i had them replace the intale & sure enough they did see major leaks
after all said & done
The next day we found leak in new intake & called them back & they came back & found it & sealed it
But again still smelling attic . so what next
exhausting
Thanks for listening
Long story.....i know
Jimmy
Old 07-22-18, 05:45 PM
B
Few hvac companies are up to date on the best methods for air sealing, they do what they have always done. Here is a link that covers a lot of the "how-to" on sealing ducts and why.
Sealing Ducts: What?s Better, Tape or Mastic? | GreenBuildingAdvisor.com
Bud
Old 07-22-18, 06:17 PM
Attic smells
K thanku again Bud
i have ran through that web site
Appreciate everything
Jimmy
Old 07-23-18, 08:35 PM
Attic smell RESOLVED!!!
Bud i wanna Thankyou for all your suggestions tryn to help us out
finally figured out the problem......
The new intake that the guy put in was leaking! -
Took care of that and we are good to go
Finally...
Jimmy
Old 07-23-18, 08:59 PM
B
Thanks for "the rest of the story". Always nice to hear a happy ending.
Bud
