Timed Home Ventilaton not working
Received 0 Votes
Hi
I have a Ruud gas furnace and a heating system in my townhouse. Have not added an air conditioning system yet.
There is a timer attached to the outside of the furnace and it turns on the fan and provides ventilation inside the townhouse every hour or so. I can hear the fan running on a regular basis to provide ventilation even when the heater is not running (as is the case right now during summer months)
I noticed that the ventillation has not been running at all in the last few days. I don't know if I pressed the wrong button on the control panel in the living room. I even tried to move the fan setting from "auto" to "on" but it still does not run the fan
I checked the circuit board and it is not tripped
Is it broken?
Does timed venitlation run if there is no air conditioning system and the home temperature is over the settingin the thermostat?
Is it broken?
Try running the heat and see if the blower comes on with that.
There only needs to be a two wire connection to the furnace for the blower to operate. Basically it's a short across the R and the G terminal on the furnace control board.
You can test this yourself by removing the blower door, holding the safety switch in and shorting from R to G. Nothing needs to be disconnected for the test.
Received 0 Votes
Thank you PjMax. I tried to run the heat (without air conditioning, the inside temperature in the living room is 77 right now, and I cranked up the thermostat to 85 heat but no luck. Blower did not come on.
The R and G terminal test is way over my head. I wouldn't even know where to look, and if it is a bad board, I wouldn't know how to fix it. I looked and could not tell where the safety switch is and where the R and G terminals are...
I have an HVAC gentleman coming in this week to do an estimate for a new air conditioning system, so I should probably have him service the blower as well, and see if he can fix it, because the furnace system is probably due for routine maintenance (I recently moved and I don't know if any maintenance has been done in the past 4 years since the house was built).
How quickly does the air quality go bad if the system is not ventilating every few hours? It is hot out there and I have the windows closed during the day. I do open the windows early in the morning and run a box fan to move the air around....
Most people don't have their system set to circulate the air.
If they do have their system circulate air it's only to try and equalize temperatures throughout the house.
Received 0 Votes
Hi Pete
If the doors and windows are not opened on a regular basis, especially in a newer house where everything is sealed tight, wouldn't the lack of a air circulation system/ventilation system affect air quality?
Received 0 Votes
A furnace does not normally draw in outside air so running it won't help draw in outside air.
The technician was here to do a quick estimate of the cost of installing an AC unit and coil to the existing furnace system and did not have the time or tools to test why the blower was not working. They will be in in about a week to install the AC and take a look at the blower as well.
I didn't realize you had two similar threads going. I removed your mention of pricing of your new system and I moved the reply I had here to the other thread.
We'll keep the pricing and discussion of the new system in the other thread.
