Can someone tell me what vent this is?
Old 06-19-19, 04:44 PM
Received 1 Upvote on 1 Post
There is a vent cover at the back of my house, but I am not sure what it is venting. I also have to replace it due to a crack. It looks like there are 4 screws holding it into the brick. Should it be fairly easy to remove? Thanks
Old 06-19-19, 04:56 PM
P
Received 2,224 Upvotes on 1,985 Posts
Most often those are clothes dryer vents but it also could be from a bath exhaust fan if you have a bathroom in the basement.
Old 06-19-19, 05:03 PM
XSleeper's Avatar
Received 1,945 Upvotes on 1,746 Posts
Additionally it might even be a fresh air intake if there is only screen and no damper on it.
Old 06-19-19, 05:26 PM
There is only a screen, no damper. It can't be venting the dryer because that is in a different location. I think it must be an air intake because I believe the bathroom fan vents in a different place.
Old 06-19-19, 05:42 PM
XSleeper's Avatar
A gas fireplace or gas water heater or similar sometimes requires that fresh air. At least some older installs were done that way.
Old 06-20-19, 04:33 AM
P
An easy (but dirty if you have to go into the crawl space) way to tell is look on the other side of the foundation wall and see where it goes.
