Dryer vent ducting
Old 08-19-19, 11:45 AM
L
Dryer vent ducting
Our clothes dryer vent is right next to a heat pump. Lint clogging our old heat pump was a serious problem. When we replaced the heat pump I put a diverter over the dryer opening to deflect the air and lint sideways. Now it is messing up the siding. I can't point it down as it will put moisture under the house as there is a foundation vent nearby. I'd like to put a pipe at ground level out past the heat pump. Any ideas would be greatly appreciated!!
Old 08-19-19, 07:30 PM
pugsl's Avatar
Received 76 Votes on 69 Posts
Use hard medal duct pipe and put it anyplace. Do not use tomany 90's as they will restrict air flow from dryer. Pipe willl be ugly is only problem.
Old 08-19-19, 09:21 PM
L
Unfortunately, ugly is not an option!
Old 08-19-19, 09:35 PM
XSleeper's Avatar
Received 1,528 Votes on 1,372 Posts
Looks like it was messing up the siding before.
Maybe try this kind. https://www.amazon.com/HEARTLAND-21000-Energy-Saving-Closure/dp/B00009W3I4/ref=asc_df_B00009W3I4/?tag=hyprod-20&linkCode=df0&hvadid=198100801330&hvpos=1o4&hvnetw=g&hvrand=15650948980961593485&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9024868&hvtargid=aud-801381245258la-318599266990&psc=1
You should be cleaning your lint filter before every load. If it's not catching most of the lint I'd say the dryer has a problem. Plus clean your siding as needed. After you get it clean, Pledge furniture polish and other similar products work well to keep the siding slick and new looking by waxing the surface.
The sideways hood is a great way to invite mice in. I doubt it ever closes fully.
Norm201 voted this post useful.
Old 08-19-19, 09:37 PM
Received 2,956 Votes on 2,667 Posts
You'd need to use 4" aluminum pipe as it won't rust. You could paint it.
Old 08-19-19, 09:46 PM
L
Yes, the lint filter is cleaned after every load. It seems to be a fine mesh, but obviously a lot of lint must bypass.
Old 08-20-19, 02:41 AM
pugsl's Avatar
Dryer repairman and you will not be able to keep lint out duct. Ant mesh fine enough to keep trap lint will restrict air flow.
Old 08-20-19, 03:57 AM
Norm201's Avatar
Received 594 Votes on 531 Posts
XSleeper's suggestion looks like a perfect solution.
Old 08-20-19, 05:06 AM
A
Received 72 Votes on 65 Posts
I couldn't get the link to open earlier so wasn't sure, but yes, the one that Sleeper linked is exactly what I would try. I don't have one myself because I've never had any issues with the conventional one we've had for years, but have installed this style when I've replaced ducts for others and think they're the cat's pajamas. If you do go with a metal duct though, I think I would run it inside a slightly over size PVC for added protection.
Old 08-20-19, 06:57 AM
L
Interesting idea of using PVC pipe as protection for the metal duct. I could use 2 - 45 degree elbows to get it close to ground level. I would need some sort of termination/damper, something like this?
https://www.amazon.com/Dundas-Jafine...MT12TC929HSHC9
