What is the hole for and can I cover it?
Old 06-20-20, 10:32 PM
B
https://imgur.com/a/MXJEYsL
Because the hole is annoying. I wanna remove the carpet and lay plywood all over area, covering the hole.
Old 06-20-20, 10:38 PM
Received 1,185 Votes on 1,097 Posts
That looks pretty big. Almost like a return line to an HVAC system.
Is there an air handler/furnace in the basement that it connects to ?
If it's in use it shouldn't be covered over.
Old 06-20-20, 11:31 PM
Received 79 Votes on 74 Posts
It's a return or supply duct, your missing the register cover for it.
Old 06-21-20, 04:42 AM
Norm201's Avatar
Received 255 Votes on 229 Posts
What room is it in? If it's a room with non-outside walls and it's a heat source, you could cover it. But if it's a cold air return I would not cover it. That would upset the heating balance of the HVAC system.
Old 06-21-20, 05:20 AM
Received 330 Votes on 293 Posts
It looks like a return vent to me also. Assuming it's in use I wouldn't block it off. You need to measure the size and buy the right floor grille for it. Many houses [especially older ones] have fresh air returns in the floor.
