Air filters in return vents
I have a Goodman ARUF3030 air handler, which has a poorly designed air filter slot. It requires removing two awkwardly placed screws (which get more and more loose the more they are removed/replaced), and the base isn't perfectly aligned with the cabinet so the filter gets snagged on the sheet metal. I literally have to yank on the filter to get it out, and it tears apart as I remove it. Thus, I am considering removing the filter from the air handler and putting individual filters on each of my three returns. This would make it much more convenient to replace the filters and I like the idea of being able to see the filters so I know when they need to be replaced. I also would no longer have to clean my main return duct as the return filters would keep them clean. As long as the filters I use aren't overly restrictive, is there any reason not to do what I am proposing?
If the return duct work is well sealed...... using three filters would be fine.
ferd42 voted this post useful.
The air handler is no more than 5 years old. I know for a fact that the return ductwork is tightly sealed. Perhaps I could do pleated filters on all the returns and a cheapo fiberglass filter in the unit to protect against anything that gets sucked in through leaks. Then check/replace the fiberglass filter once a year.
Also forgot to mention the filter is a non-standard size, so I have to special order them online. Not too big a deal as I get them in bulk, but just another inconvenience.
DO NOT add filters to the system, especially pleated ones: It's extremely likely airflow is substandard now, and you'll only make it worse be increasing resistance to flow. Think "Replacement Compressor" in a worst case scenario.
