New Radon Fan Manometer Reading
Received 0 Votes
My old fan was loud as heck so I replaced it with a best guess since the original was installed for the previous owner and had no s/n or identifiable markings. The new fan is whisper quiet but I'm concerned I may need to upsize it.
The old fan was reading about .4 or .5 on the manometer. The new one is only reading about .3. Is this a concern? It levels out correctly at 0 when turned off.
I am going to start a radon test in a few days (the kind that you send in for results). But am curious if anyone thinks I should upsize the fan no matter the results.
Agreed. Unless you have a significant radon issue (50-100+ pCi/L), really any air extraction will be sufficient. The fan is just pulling the air that may be contaminated instead of allowing it to seep through the slab and foundation.
I think you're all set with a working fan!
