odd situation about HVAC permit
Old 05-28-21, 09:00 PM
C
I'm finishing my basement. I started work last year and added a few vents to condition different zones of my basement last summer. I simply tapped them into the main trunk. My whole project was delayed and I'm now getting ready to put up drywalls. BUT I was told by my plumbing inspector yesterday that I need to have a licensed HVAC contractor to pull permit and get it inspected, and this is a new requirement by county effective Jan this year. He was telling me that I need the calculation and proper duct sizing etc.
I don't know what that would entail as I have installed the ductwork and made soffit around them. I will have a contractor coming in next week to take a look and let me know what's cost to get it pass inspection. I'm really worried if they ask me to rip off the soffit to update the duct sizing. It really sucks.
Has anyone ever dealt with this situation before? what does inspector really look for during the inspection?
Thanks!
Old 06-01-21, 05:01 PM
H
Those are all questions for your city/inspector.
Old 06-02-21, 01:18 PM
I
Received 35 Votes on 29 Posts
You have said the ductwork was finished before the new requirement was put in place. If you got a permit for the work a year or more ago, it wouldn't be reasonable to expect you to also be psychic and predict what new regulations would be dreamed up after the work was done.
Old 06-03-21, 03:01 AM
Received 673 Votes on 596 Posts
^^^ was a permit required for the work you did a yr ago?
Old 06-04-21, 01:48 PM
C
No. The permit was not required prior to 2021. I talked with an inspector today. He said drawing must accompany the permit application as well as a signed affidavit from master license holder that the existing system has been calculated for additional load. Manual J will not be required.
So now I have to find a licensed contractor to retrospectively apply permit.
Old 06-11-21, 10:24 AM
A
You need a permit if you will rent the (space/room/basement) as a living area for a citizen.
For "a real job", the ducting is supposed to be separate, on a separate fan: you should read the building code: why didn't you???
You can't duct air pulled from one apartment and dump it into another apartement. Nor can you have ducting which allows one apartment to "fish a camera into the other apartment" (the ducts cannot be connected).
Your AC/HEAT requires you pull circulate all the air 3x per times it turns on (say, every 10 min of operation). If you connect a whole basement to a pre-existing system you need to "re-design" or you'll have bad air flow and also very poor efficiency (circulating 1.5 times is very in-efficient). so if you have 10,000 cu/ft in your home, that's 30,000 cu/ft per 10 min.
Your receiver vent has to have the opening so that it can pull air that the exit vents push out. If you didn't install a recieving vent then you need to ... leave your basement door open ? (see the next note - as having no reciver could actuall cause air to be pulled from the mechanical heat ducts for the heater and water heater: WHICH IS WRONG - YOU CAN'T DO THAT)
Your recieiver vent that pulls air has to be located at least (far) away from any vent to be effective but also it's important it is far away FROM ANY HEATER BURNER (central heat or water heater).
If you installed no receiver "techincally" your kinda ok with the burners (unless your extinguishing pilot lights or making a blue flame orange?), but your vents won't blow since there's no exit point you need to keep basement door open again.
Your local government may be a bunch of crooks. But other than that, it really doesn't matter unless your leasing.
YOUR FINE IF .... YOU MEET FIRE CODE
you remembered the building code rule about hanging ducts (IF metal ducts are connected to a furnace, then it must be hung "like the others" (not touching the wood, and special protection just above the heat box) ). i assume you hung your ducts like the other ducts ? you didn't let your ducts touch electrical wiring (though the 983743 who built your home probably didn't care and did it)
THE TWO IMPORTANT THINGS YOU MUST FIX:
* though shalt not alter air flow in mechanical ducts or pull CO from them
* though shalt not let a heater duct that's too hot due to dead fan burn the house down by contacting wires or flammables
Old 06-14-21, 08:26 PM
C
first off, I'm not renting out my basement. Not sure why this came up. Anyway, here is some update.
Our county posted this in its website now after I pointed out that they did not have it on the website:
"Beginning January 25, 2021 mechanical extensions to additions, finished basements or alterations to an existing system will require a mechanical permit and inspections.
All newly installed heating or cooling ducts and exhaust duct will be installed per the 2018 International Residential Code and the 2018 International Energy Code.
Drawings must accompany the permit application as well as a signed affidavit from master license holder that the existing system has been calculated for the additional load and it will adequately supply heating and cooling. A manual J will not be required for an alteration or addition permit. "
I called four AC firms to ask if they could help me to pull permit. Three said "no", the other said the conservative estimate is $2000. I have another guy coming in this Friday to take a look and get me a quote. They told me that the new requirement is nonsense because the county ask contractor to put their name on the line then in the end the manual J is not required. No responsible contractor would risk that so the manual J must be done. The one quoted me 2 grand will do manual J (could cost cost more depending on the result!). One of them told me some homeowner asked them for the same reason a few days ago so I'm not the only victim...
I won't be able to cough up two grand for this unplanned event so I called my inspector that I will seal the vents that I installed and put up drywall without cutting the vent so there is no "mechanical extensions to finished basements or alterations to an existing system". He said I'd have to call their head inspector to see if it is ok. I will report back the outcome.
Old 06-21-21, 04:11 AM
I
"No. The permit was not required prior to 2021. I talked with an inspector today. He said drawing must accompany the permit application as well as a signed affidavit from master license holder that the existing system has been calculated for additional load. Manual J will not be required.
So now I have to find a licensed contractor to retrospectively apply permit."
I'm having trouble understanding this.
No permit was required prior to this year. You did the work last year.
Last year is prior to this year, on my calendar.
But now you must get a permit?
What about the work that was done 10, 20, 50 years ago? Do you have to get permits for that too?
Does every house in town have to get retroactive permits for things that were built years ago?
What about electric? Plumbing? Does it all have to be re-permitted and brought up to current code if you hang some sheetrock?
Old 06-23-21, 06:40 PM
C
I'm with you on this, and the county drove me crazy. I was told that the ductwork is part of the basement reno although the ductwork was added last year without mechanical permit requirement back then. If my basement was finished last year, then I'd have not needed the permit, but my basement project is still on going, so I'd need the permit. Anyway, I talked with the head inspector and told him that I'd restore the system. He agreed that no permit is needed in the case.
"I'm having trouble understanding this.
Last year is prior to this year, on my calendar."
