Best as I can describe, the bath fan noise sounds like a variation of continuous mild thunder. I pulled the fan/motor bracket out and plugged it in to a wall outlet and it sounded fine. (I'm not sure however if I positioned it the same as in the ceiling for this test.)
--The vent outside, the type which has 5 or so horizontal flaps, was about half open. Could it be partially blocked anyway?
--Overall the housing body of the unit seems not firmly secured to the studs--slightly wobbly.
--Lastly, as you can see in the photo, there are large gaps between the drywall and fan body.
I did check to see if the fan duct flap opens at the exit. I'd say it's acceptable, but could move more freely.
I found no blockage at the beginning of the duct work also.
Check your plastic squirrel cage. That thunder noise is often the hole for the shaft getting rounded out on the impeller. Most I've seen are supposed to be flat on one side.
Hello, I have a 1993 double wide mobile home. I believe some part of my ductwork has been compromised somehow as I only have heat coming out of one side of the trailer vents. When I crawled under the trailer it is very difficult to see any ductwork as there is some kind of like black fabric with insulation above it covering almost everything. Any ideas what I should do? I called around and none of the HVAC companies will even mess with it? Ideas? Thanks!
We are exploring the use of an Air Purifier, we have 3 small dogs and the assumption is they are the biggest contributing factor against the Air Quality in the House.. The house is 938 sq ft including the Basement.. Curious how often the Filters would have to be changed or cleaned ?? Something affordable and won't break the Bank.. Thoughts & Ideas Appreciated, Cheers Thanks
