Extending Register Boot Below Soffit
Old 01-05-23, 08:42 PM
I have two vent registers located along main trunk lines in my basement which are now framed inside soffits, and I need to lower them:
I bought two of these rectangular starting collars from HD and I don't understand how the tabs work. Why aren't they single-layered like all the round collars I've seen? Do I just insert them into the hole and bend back the perpendicular ends of each tab? Seems like that would leave kind of a bump along the outside edges of the rectangle. Or should I snip off the extra folded-back metal and screw through the remaining flaps into the trunk? Is there a third method I'm not seeing?
Old 01-05-23, 09:30 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
You stick it in, put your arm in, and bend all the tabs down. Then foil tape the edges of the flange.
Old 01-05-23, 10:48 PM
Got it. So having a small bump around the edge due to the double-layered metal there is expected?
Old 01-06-23, 05:19 AM
XSleeper's Avatar
Yes.
Old 01-06-23, 07:37 AM
Right on, thank you!
Old 01-06-23, 08:17 AM
P
Received 1,840 Upvotes on 1,647 Posts
Make sure you use foil tape and NOT gray duct tape. You can also use duct putty to seal any minor openings and stop air leaks.
