Patch holes in ducts
Old 07-09-24, 04:47 PM
In the hvac ducts in my garage are leaking air pretty bad. A couple of spots where pipes go into the ducts near the blower, the pipes were sealed with some sort of black, gooey tar substance and there is a minimal amount of tar where it is leaking.
My question is, what is this stuff and should I slap some more on there or should I try to pull it all off and use some metal tape?
Thanks
Old 07-09-24, 05:49 PM
Tolyn Ironhand's Avatar
Received 914 Upvotes on 772 Posts
I'm not sure what the black stuff is but these days HVAC guys use mastic. Example:
https://www.homedepot.com/p/Master-F...A100/301784793
Old 07-10-24, 04:44 AM
P
Received 2,319 Upvotes on 2,064 Posts
I use a mastic called Duct Putty. It comes in a tub and it's a medium to thick putty you goop over any openings or air leaks.
