Kenmore Dryer 90 series No Heat
Old 06-06-03, 09:28 AM
AJW
Question Kenmore Dryer 90 series No Heat
How do I get to the heating element? It looks like they tack welded the back shut. Help!!!!!
AJW
Old 06-06-03, 09:51 AM
jeff1
Cool
Hi,
Kenmore is made by several different companies...a full model# usually will help to see what style/kind you have...
http://www.applianceaid.com/model.html
Model# helps.
http://www.applianceaid.com/dryers.html
Many common dryers with take apart infos...
jeff.
Old 06-06-03, 10:27 AM
AJW
The Model # is 66912690, Some other # that was by the model # is 66912, the Sereial # is MF3310419, Does this help?
AJW
Old 06-06-03, 01:43 PM
jeff1
Smile
Hi,
I got 110.66912690 to work.
From the front bottom....
http://www.applianceaid.com/whirlpool-dryers.html#four
The element is in a tube on the bottom/right area.
Heating element assembly
http://www.repairclinic.com/referral.asp?R=153&N=525502
http://www.applianceaid.com/faq-dryer.html#elecheat
From the FAQ sections...
Q - My electric dryer runs but will not heat, what could stop my dryer from heating ?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug ...
Does this help?
Sure
jeff.
Old 06-06-03, 08:20 PM
AJW
Should there be continuity in the thermal cut off?
AJW
Old 06-06-03, 08:46 PM
jeff1
Cool
Hello,
Yes.
You can join the 2 wires together as a test only to see what happens.
Thermal cut-out (fuse) L360 and high-limit thermostat L250 kit, 1ea.
http://www.repairclinic.com/referral.asp?R=153&N=2821
jeff.
Old 06-06-03, 08:59 PM
AJW
Thanks !!! You have been a very big help!!!
AJW
This is my site.
Old 06-06-03, 09:13 PM
jeff1
Smile
Your welcome!!
Thankx for the link.
jeff.
Old 11-04-07, 01:06 PM
C
how did you get the back panel off. i have the same model (kenmore 110.62992100)?
i took the hex screws off the back, but it seems to be tack welded every 16" or so along the both sides and where the back panel meets the top of the side panels (right angle the back of the top of the dryer...on both sides).
Old 11-04-07, 04:35 PM
D
Hi cheeky:
On yours you have to come in thru the front.
Go to www3.sears.com type in your mdel # then select cabinet, open the diagram. Look down at the seam between the door section and the lower panel. See that thing called retainer on the left? Slip a thin putty knofe or an old credit card in there and push to release the clip and rotate the panel out. Then locate the thermal cutoff on the heater element box and test it. Are the dryer and the exhaust hose/pipe full of lint? If the thermal cutoff is bad, you'll get a kit that also includes the high limit thermostat. If the TCO is blow and the dryer and vent are clean, replace the operating thermostat as well. Let us know how you make out.
