Maytag Neptune MAH4000aww
  #41
Old 02-09-09, 05:05 PM
K
Originally Posted by pugsl View Post
junk machine many problems with that one. Sound like motor and motor control board going bad. There is no reset switch and I can't guess what he did to get you another year.
wow to my surprise the machine started spinning again so maybe something odd is happening?
for now it is working, am starting to search for replacements.
boy are they expensive now!
  #42
Old 03-10-09, 08:44 PM
P
I've experienced about every problem these units have. The last issue I had was the no drain/spin periodically. The drain pump worked fine 80% of the time. I was told it was the control board. Well the problem ended up being the drain pump itself. SO you neptuners having the no drain issue and your control board isn't burnt it's time to replce the drain pump. Took 2+ years to find the actual problem. Thought I'd share my experience to help others. Pete
