Jenn Air Convection Oven
Old 03-21-03, 03:41 PM
davejohn_tx
Post Jenn Air Convection Oven
Jenn Air Convection Oven 2 years Old Model WW30430P. Control panel oven temperature indicator leds went dark, not visible. Any replaceable part on the circuit board that will cause this?
Old 03-21-03, 04:33 PM
jeff1
Smile
Hi,
This is a very complicated oven!!....and at 2 years old...may still have some parts warranty!
http://www.applianceaid.com/phone.html#M
Maytag ( they own Jenn-Air ) contact #'s.
http://www.repairclinic.com/0081.asp?RccPartID=695197
Electronic clock control
If the clock/control is receiving power but won't lite up....the clock/control would be suspect...if the clock is not receving proper power....your range has 2 relay boards and many wiring harness between the clock/display/control and those relays boards that would be suspect.
Relay board lower...
http://www.pcappliancerepair.com/cgi...1893&brand=MAC
Relay board upper...
http://www.pcappliancerepair.com/cgi...2595&brand=MAC
jeff.
Old 10-04-07, 10:08 AM
R
Unhappy
I'm having the same problem with another model (JJW9527AAB) Jenn Aire Convection Oven. I wonder if this is a common problem with Jenn Aire. I'll try to contact their tech support, but if anyone has information, please post it here. A repair center said my clock and board were bad (part #71003424) and would cost $185 just for the parts.
