kenmore washer model 11082694540 will not spin
Old 02-09-04, 10:50 AM
Reyes
My Kenmore washer will only start spinning if I set on low spin first then after it starts spinning I deactivate the low spin button and it'll continue spinning at the normal spin speed. Sometimes it won't start in low spin unless I turn the tub counter-clockwise manually. Noticed oil coming out of direct drive transmission. Any help appreciated.
Old 02-09-04, 12:10 PM
mike_4758
It could be many things. Check:
-Coupler between the motor and tranny
-with power off try to turn the tub by hand, if you can you may need a drive yoke and spin tube.
-if all else fails than you might want to change the tranny, the have a warrantee for 10 years.
