Agitator in a GE Washer does not spin
Old 02-10-04, 02:24 PM
WSilva
I own a GE washer model # wjsr2080t8ww. Serial # ms163894g its fills up but the agitator does not move on any setting. I am new to any of this but i am pretty handy with tools.The washer is about 6 yrs old. This particular model was made 1997. What do you recommend. thank you.
Old 02-11-04, 06:49 AM
Sharp Advice's Avatar
Admin Emeritus
Hello: WSilva. Welcome to the Do-It-Yourself Web Site.
Check the door safety switch. If it is not closed fully or defective, the machine will not operate. Some machines allow all cycles except the spin cycle to operate when the door is opened while others do not allow any cycles to operate.
Depending upon the type of safety button used, you may be able to hold the button closed with a finger if it is not the recessed type. If it is, use a thin blade screw driver.
May also try a continuity test on the switch. be sure the electric power is turned off first and also prior to any other tests done for continuity.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions, test and or repair methods.
If you need further assistance, use the reply button to add any additional information or questions. Using this method also moves the topic back up to the top of the list automatically.
Regards & Good Luck. Sharp Advice.
TCB4U2B2B Business Management Services.
Web Site Host, Forums Monitor & Multiple Topics Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
