Question about watercoolers?
Old 02-17-04, 04:11 AM
Disciple
With watercoolers can you get the air to come out cooler by putting in ice cold water? Thanks
Old 02-17-04, 06:53 AM
Sharp Advice's Avatar
Admin Emeritus
Hello: Disciple
If the unit is the type used to cool room space, has a blower and straw pads with a water circulation system to keep the four sides wet as incoming air passes over the wet pads, we call these units swamp coolers.
If this type of water cooler is the type of unit you are referring to. If not, kindly explain in more details.
Certainly cold water would help. Problem is where to get a constant supply to keep the water holding tube supplied. Filling it with cold water would work at first, initially, but soon the water supply would reach outside air temp and defeat the purpose.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, and suggestions.
Regards & Good Luck. Filling in to help in this forum topic.
Sharp Advice. TCB4U2B2B Business Management Services. Web Site Host, Forums Monitor & Multiple Topics Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
