GE washer
Old 02-19-04, 04:39 PM
harvinder
GE washer
I have a GE washer about 13 years old.It appears working alright but the clothes remain very wet at the end of the cycle and there is some water left in the outlet pipe.
Kindly give some advice.
hx
Harvinder
Old 02-19-04, 05:33 PM
Sharp Advice's Avatar
Admin Emeritus
Hello: harvinder
One of several possible problems. Too many clothes overloads the machine. Try smaller loads.
Next possible cause, spin cycle spins too slowly.
Restriction in the machines discharge line, etc.
Pump motor wornout or the pump itself is worn out.
Retail appliance parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers. Appliance part stores and dealers are listed in the phone book.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions, test and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Regards & Good Luck. Filling in to help in this forum topic.
Sharp Advice. TCB4U2B2B Business Management Services. Web Site Host, Forums Monitor & Multiple Topics Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 02-20-04, 07:21 PM
cajon ken
while holding an object in the lid switch hole place the washer in the spin cycle and see if it is really turning fast enough to get the water out. Then remove the hose from the bottom of the tub, After removing as much water as possible from the tub, and see if there may be an article of clothing stuck in the drain hose or up between the inner and outter basket. The next check would be at the water pump. Check inside the hoses and if you canremove the pump look inside it for damage or foreign materials.
Old 02-20-04, 08:12 PM
Grace Elliott
G.E. washer
My husband said it sounds like the drive belt.
