"clicking" fridge
Old 02-20-04, 08:29 AM
CHAINERS
"clicking" fridge
I have a Chevrolet Coldspot fridge which makes "clicking" noises when it turns on. It clicks on, then clicks off, clicks on, clicks off, and does this up to seven times before the fridge actually kicks in. What could the problem be and should it be fixed. The fridge is still cold and so is the freezer, but it is very annoying.
Old 02-20-04, 09:27 AM
Sharp Advice's Avatar
Admin Emeritus
Hello Chainers and Welcome to the Do-It-Yourself Web Site.
Chances are that clicking noise is comming from the starter on the compressor motor. Not something for a do it yourself person to tackle. It's not the electrical current to be so concerned with, it's the refrigerant loss and replacement that will result.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions, test and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Regards & Good Luck. (Adding my two cents in this forum topic)
Sharp Advice. TCB4U2B2B Business Management Services. Web Site Host, Forums Monitor & Multiple Topics Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 02-22-04, 10:49 AM
Mglines
It is possible this problem could be just a bad start relay. We use a kit called an RC0-410. You should beable to purchase this for around 25-30 bucks at any Appliance store. Installation is pretty simple and the people at the Appliance store should beable to help you with this. We do atleast. If the relay doesnt fix your problem then most likely you need a compressor which would mean buying a new Frig.
