Maytag stackable/washer-dead??
Old 02-21-04, 05:48 PM
RayandJen
Waher-7yrs old-opened lid -could not get it to run again!? It did spin cycle-once! It will not do anything now. I think it might be the lid switch-but can't figure how to get lid off!? What do you think it might be??? Thanks for any help!!!!!
Old 02-21-04, 06:08 PM
Sharp Advice's Avatar
Admin Emeritus
Hello RayandJen and Welcome to the Do-It-Yourself Web Site.
It very well could be the door lid switch. Try holding the lid switch button down with a rubber handled thin screw driver. Keep the door opened during this process. Attempt to run the washer and note what happens.
If the machine begins to operate, the problem is the switch. Chances are the switch is not broken and this test cannot be done. If the machine will not operate, the switch is damaged.
Access may be gained by removing some screws on the lower front of the front panel. Or there may be clips between the top and the front panel.
If there are clips, may be visable using a flash light to look between the top and the front panel. The clips push backwards to release the lip fron the front panel. An old credit card often works when slipped between the two parts.
If you open the lid, be sure the power is off or the plug is removed from the wall socket. Than look for a fuse on the main power cord inside the machine. Some machines have fuses.
Read the manufacturers online web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, downloadable repair and or owners manuals which may be available online.
Another possibility may be to search the manufacturers web site for a downloadable version of the owners or service manual. The file will be a pdf file opened with Adobe, which also needs to be downloaded but worth having the Adobe once obtained.
http://www.maytag.com
(copy & repaste into browser)
Retail appliance parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers. Appliance part stores and dealers are listed in the phone book.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions, test and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Regards & Good Luck. (Adding my two cents in this forum topic)
Sharp Advice. TCB4U2B2B Business Management Services. Web Site Host, Forums Monitor & Multiple Topics Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
