Refrigerator cooling unevenly
Old 02-28-04, 01:17 PM
JayB
I have an Amana side by side refrigerator/freezer. The refrigerator temps are arying from 50 degrees F on the top shelf, 22 degrees F on the middle shelf, and 36-40 F on the bottom shelf. Any ideas?
BTW, the freezer works fine.
Old 02-28-04, 05:54 PM
appliancepresid
Hi JayB,
a couple things to look at would be the damper controls
Some even have automatic dampers it may be malfunctioning, also check if fan in freezer is running , check if frost is found on back wall of freezer( upper , middle and bottom back wall in freezer)
If shelves are wire rack style check if anything is restricting air flow on shelves. ie... pizza box
