GE washer and dryer
Old 03-02-04, 06:22 PM
swdjraia
GE washer and dryer
Noticed water in floor mainly in front of dryer. Clothes seem to contain more water than usual when completing the wash cycle. Seems to take clothes longer than usual to dry. Does this combination of symptoms, indicate an apparent problem with the washer? If so, is it something I can attempt to correct myself?
Old 03-03-04, 05:57 AM
Sharp Advice's Avatar
Admin Emeritus
Upvotes Received: 5
Hello swdjraia and Welcome to the Do-It-Yourself Web Site.
Washers which do not pump out all of the water usually are not spining fast enough to pump out all the water. Usually caused by overloading with too many clothes or an unbalanced load.
Try washing less clothes per load. The intent is to determine if there is a problem with the washer or this incident is one isolated case. Before assuming there is a problem with the washer.
Other possibilities may be the pump, pump motor, restricted water discharge line in the washer, timer, while in the spin cycle, spin cycle may be too short, etc.
For more detailed information read the recent postings within this forum. The questions already asked describe like or similarly related problem descriptions as your question. Those prior postings and all the replies offered within them contain almost all the required information needed.
Read the manufacturers online web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, downloadable repair and or owners manuals which may be available online.
Retail appliance parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers. Appliance part stores and dealers are listed in the phone book.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions, test and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Regards & Good Luck.
Sharp Advice. TCB4U2B2B Business Management Services. Web Site Host, Forums Monitor & Multiple Topics Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 03-03-04, 10:39 AM
swdjraia
Ge washer and dryer
Thanks for your reply. I will try your suggestions. The restricted water discharge line rings a bell. Is it possible for something small like a sock to get in under the agitator and clog up the line?
