Oil Stains from washing machine?
We have an Amana extra large capacity washing machine that is 11 years old.
We have been noticing grayish/brownish/greenish stains on our whites. Is this what oil stains look like?
We were told a possibility is oil stains from the agitator (?).
My husband said washing machines are expensive, but not as expensive as a new wardrobe!
TIA!
TIA!
Received 7 Upvotes
Hello: SusieQT
Most likely there is a worn and leaking seal beneath the agitator. The top of the agitator is the cap which can be removed. Inspect the area beneath it. To access the seal the entire tub has to be removed. Each machine differs on how this it done.
Read the manufacturers online web site for problem possibilities, solving methods, disassembly, reassembly methods, repair procedures, pictorials, downloadable repair manuals, etc which may be available online.
Search the manufacturers web site for a downloadable version of the owners or service manual. The file will be a pdf file opened with Adobe, which also needs to be downloaded first but worth having once obtained.
Retail appliance parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers. Appliance part stores and dealers are listed in the phone book
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Regards & Good Luck. (Helping out in this forum topic)
Sharp Advice. TCB4U2B2B Business Management Services. Web Site Host, Forums Monitor & Multiple Topics Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Personal Reminder:
Received 7 Upvotes
Hi: SusieQT
First, what I left out of the first reply is to remove the agitator cap and than pull up on it and remove it from the center drive spindle. Once it is removed the seal, etc can be seen and possibly gain access to it. Possibly but not always.
Other Causes Possible:
Cleaning may help all the exposed parts may help. May have had a prior greasy item washed which left behind the grease or whatever is causing the current problem.
How long a machine or any of it's parts lasts, has far too many variablies. All based on usages, how built and maintainence. Hard to say for sure. May last you 6 years, others 10+...????
Each machine differs. How to access the seal on that specific machine is not know for sure. May have to remove much more than just the agitator top side. Likely from beneath the machine.
Search the manufacturers web site for a >downloadable version of the service manual< May be available online.
Retail appliance parts dealers can also help determine what the possible problem may be and how to fix it.
Bring the make, model and serial numbers. Appliance part stores and dealers are listed in the phone book.
Web Host & Forums Monitor
