Amana Washer Balance Problem
Old 04-30-04, 09:14 AM
royandfam
Post Amana Washer Balance Problem
Amana Heavy Duty Super Capacity - 31315 (Approx 1997 model)
Spin cycle gets out of balance too easily. Light loads help some, but towels, jeans, etc throw it WAY off. Had the transmission replaced under warranty several years ago by dealer (begrudgingly) and suspect they may have inadvertantly left something out. It's been doing this for a while, but seems to be getting worse. Suggestions? Are there supposed to be some type of stabilizer rods? If so, how many? Is this enough information to answer this query?
Old 05-01-04, 08:14 PM
Sharp Advice's Avatar
Admin Emeritus
Upvotes Received: 5
Hello: royandfam
First unplug the machine. Remove the back panels to access the washer tub and drum. Drum may have balancers on the tub and or springs. Adjustment may be needed. Once the panel is off the problem may be evident.
Recently had a question pertaining to the same problem. Check and read for pior postings pertaining the washers. Likely to find the answer to the problem with any one of those posts with replies.
Additional Help and Suggestions:
Read the manufacturers online web site for problem possibilities, solving methods, disassembly, reassembly methods, repair procedures, pictorials, downloadable repair manuals, etc which may be available online.
Search the manufacturers web site for a downloadable version of the owners or service manual. The file will be a pdf file opened with Adobe, which also needs to be downloaded first but worth having once obtained.
Do an online search for the model by brand name or use a search engine web site like goggle etc. This web site also has help info. All of which can be found in the banner above at the top of this page.
Retail appliance parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers.
Appliance part stores and dealers are listed in the phone book. May find some help on the pages listed at the top of this page in the banner topics.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Regards & Good Luck.
Sharp Advice. TCB4U2B2B Business Management Services. Web Site Host, Forums Monitor & Multiple Topics Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 05-04-04, 11:36 AM
Trying2Help's Avatar
Sounds like a spring/strap on the drum either came loose or broke. Does your drum lean to one side?
Do you have a model #? These are set up differantly, but you should be able to spot the spring/straps if the cabinet is off.
