Whirlpool Dishwasher won't drain
Old 06-03-04, 01:03 PM
hubbert
Question Whirlpool Dishwasher won't drain
Portable Whirlpool Dishwasher 14 years old.
How do I remove the drain impeller to see if there is anything clogging it? I have removed the wash spray arm and the wash impeller, the macerator and the macerator spring. I have also checked that nothing is blocking the drain hose.
How do I, or can I remove the drain impeller? There doesn't seem to be any screws holding it in - does it just lift off?
Old 06-03-04, 01:13 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello: hubbert
Below are a few web sites which can help provide the information needed. You will ned to copy and repaste the addresses into the browser. The addresses cannot be dirct links because the codes allowing such in the forum topic have been turned off until a moderator is found.
Whirlpool's Home Web Site: (Also makes appliances for Sears)
http://www.whirlpool.com
Also try this web site:
Sears Home Page:
http://www.sears.com
Sears Search By Model Number Page:
http://www3.sears.com
Additional Help Sites:
Appliance Parts, Pictures & Help:
http://www.PartSelect.com
Appliances Parts & Help:
http://www.pcappliancerepair.com
Kitchen Appliance Parts:
http://www.parts-depot.online.com
DIY Help Links:
http://links.doityourself.com/
http://links.doityourself.com/links/appliances/
Additional Help and Suggestions:
Read some of the existing posts in this forum. In them will have additional ideas and or suggestions, along with repairs procedires, etc.
Read the manufacturers online web site for additional product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, downloadable repair and or owners manuals, which may be available online.
Search the manufacturers web site for a downloadable version of the owners or service manual. The file will be a pdf file opened with Adobe, which also needs to be downloaded first but worth having once obtained.
Do an online search for the model by brand name or use a search engine web site like goggle etc. The do it yourself web site also has help info.
Retail appliance parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers.
Appliance part stores and dealers are listed in the phone book.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions, test and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
TCB4U2B2B Business Management Services. Web Site Host, Forums Monitor & Multiple Topics Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
