Whirpool Dryer-- Electric
Old 06-04-04, 04:28 PM
REALTYTIP
Unhappy Whirpool Dryer-- Electric
QUESTION---HELP
TIMER PROCEED AROUND TO ALMOST THE STOP POSITION THEN WILL NOT CUT OFF. First I replaced the timer assembly and the problem remained. With help from the parts distributer(they thought the timer should have fixed the problem) I have purchased the on/off switch. He told me to start the dryer then to pull off one lead of the switch after starting the dryer to chech if the on/off switch was in fact bad. This I did and the problem remains.
Any suggestions?
I am stumped!
Realtytip
Old 06-05-04, 08:43 AM
appliancepresid
Hi Are you running the timer in timed dry cycle or " more or less" dry cycle.?
If so equiped,
