Kenmore Elite Model 110.21082000
Old 06-06-04, 07:45 AM
cbelcher
Morning all,
I have a 2 or 3 year old Kenmore washing machine with "CALYPSO" wash motion. The other day while doing a load of wash the machine threw a "FL" code. After a little research I found that it meant that the washer was over filled. As the user manual stated the washer tried to bring the water level down by cycling the pump on and off every 30 seconds. When the pump cycles its motor sounds like its straining and no water is removed from the machine.
My first question is how do you open the blasted thing? I was able to open a small access panel at the rear of the unit, but I can't really get to the pump.
Thanks in advance
Craig
Old 06-06-04, 10:35 AM
cbelcher
Underwire from Wifes Bra
Fixed it! There were two small clips in the front that hold the top down (between the top and the front of the cabinet) I just used a putty knife to push them in (towards the back of the unit) and the top lifted right up
I took the pump apart and found an under wire from one of my wife’s bras
Hope this helps out someone else in the future.
Craig
