Maytag dryer won't start but buzzes
Old 06-25-04, 11:02 AM
cryogen
I have a Maytag electric dryer model DE806. It won't start, but will buzz. I removed belt from motor, turned on, motor wheel would not start, still buzzing. However, if I help the motor wheel turn, it will start and continue to run with no buzzing. Would appreciate advice.
Thank you.... Craig
Old 06-25-04, 10:54 PM
Doc Electric
Your motor is probably bad or it has a bad start switch. Doc E
Old 06-26-04, 07:14 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello: Craig
If the motor will not start rotating by itself, with or without the belt on it, the starter windings, within the motor itself, are defective.
Two choices to fix it:
Have the motor repaired at a local electric motor repair shop.
(May cost as much or close to as much, as a new motor)
Replace the motor with a new one.
(Replacement motor can be purchased at any local electric motor sales and or repair shop or any local appliance part stores in your area.)
Retail appliance parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers. Appliance part stores and electric motor repair shops are listed in the phone book.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions, and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list of current questions automatically.
Web Site Host, Forums Monitor & Multiple Topics Moderator. Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
DRYER SERVICE TIP:
It's always adviseable to clean the entire exhaust venting system every 2 years. Or during any dryer maintenance, connection and or repairs.
