Frigidaire Smoothtop range
How do I pop the top, lift the smooth top for access to the infinite switches?
Received 5 Votes
Hello: Tom
Not sure exactly how that is done. I deal only with gas appliances. Nor sure anyone posting replies in this forum topic does either. But there are two possibilities that come to mind.
Remove the entire counter cooktop. Turn it over and remove the metal casing and access should be available throught the bottom underside. Inside the cabinet should be holding clips to remove the glass top.
Another method would be to inquire at any local appliance parts store. These businesses are listed in the the phone books.
Regards & Good Luck
Sharp Advice
Web Site Host & Forums Monitor
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Regards & Good Luck
Sharp Advice
Personal Reminder:
top access
should be able to lift the glass top for burner access by opening oven door and removing phillips screws under front edge of main top.
Check the burner first - that is is the more likely culprit than the infinite switch. Those burners have an overload type sensor that often can crack and render the burner inoperative. The sensor is not available as an individual part, the whole burner assy must be replaced ($$!!).
The infinite switch can be checked by taking off the back panel, giviing you access to the backs of the switches for testing, but if you have to remove a switch to replace it, you must take off the top strip above the clock, which gives you access to the screws that remove the glass panel, etc.
OldmanTom
Thanks Otis. This one has a deflector for the slightly open door used during broil. Trial and error. with more screws behind that. Burner over $100.00. Ouch!! Switch is ok. They changed the part number on this burner so I'm guessing that the original burners just didn't work out.
