kenmore dryer-not enough heat
Old 10-25-04, 08:47 PM
amiallison
I have an older Kenmore dryer that does not seem to produce enough heat. Will dry very small or light loads otherwise must dry each load twice. Changed element and cleaned all venting, still the same. All else seems ok.Thanks for any help.
Karen
Old 10-26-04, 04:11 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello Karen and Welcome to the Do-It-Yourself Web Site and the Electric Appliances Forum Topic.
Although you cleaned the venting, did you remove the venting system from the dryer completely and than dryer another load? Doing that is a test. If nothing changes the problem is the machine.
If the dryer works properly without any vent attached to it, the venting system is the problem, even if you cleaned it. May be the exhaust hoods inner flapper door is not fully opened, stuck partially closed or not opening fully, etc.
Could be the arrangement of the venting system. Describe it in details. How long, any upwards inclines, how many elbows, etc. Could be the venting system design, length, bends, kinks or the machine is pushed up against it causing a restriction, etc. Describe it.
Also read the other already exisiting questions on dryers with drying problems. Those questions have already been asked and contain all the possible solutions to fix dryers that have the same problem yours does.
Retail appliance parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers. Appliance part stores and parts dealers are listed in the phone book.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list of current questions automatically.
Helping Out Here Too.
Web Site Host, Forums Monitor & Multiple Topics Moderator.
Natural Gas Appliance Diagnostics Technician.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
