Kenmore Electric Range Temperature adjustment
Hello Everyone, I am back after many days away from the DIY forum venturing on my own, but once again I find the need to ask for help. We bought a new Kenmore Electric Range, model 790.9231. In the Q&A sheet it states that you can adjust the temperature of the oven by rading the owners manual. I have read it cover to cover and it does not give directions on how to adjust the temperature that is factory set at least 20 degrees off at 375. Can someone provide the instructions to increase this oven temp. I understand the principals and don't want to have to take a day off waiting for a SEARs Tech to come out and also would like to know so I can make changes in the future should I need to.
Thanks for the help
Doug
Thanks for the help
Doug
Kenmore Elec Range Temp Ajustment Help
Can anyone help with this listed issue? Turkey day is coming fast.
Thanks
Thanks
Thanks for the help
Doug
Thanks for the help
Doug
Please anyone with knowledge! I need a reply. My work hours makes it very dificult to get service out and I know I can make the setting change if I was given the instructions
Thanks,
Doug
Thanks,
Doug
This is the link K.Gomes was speaking of
http://www.applianceaid.com/temp-change.html
I realize Thanksgiving day has come and gone, if you haven't gotten it fixed yet this may help for Christmas.
Good luck and post back
Thanks
Thanks everyone. I was manually guessing what I should set the oven on for the correct cooking temp, but the wife {the great cook she is} was just confused as to whether she should add or subtract degrees. I used the link and adjusted the temp by 10 degrees and as long as I continue to do most of the cooking everything has become eatable again. I will now enroll the wife in cooking class 101A again
Thanks again,
Doug
Thanks again,
Doug
