Washing machine will not drain or spin?
Old 12-05-04, 11:09 AM
jackman1
I have a kenmore 80 series washing machine Model# 22892100. When I set it on normal wash, it will wash fine until it get to the point where it should drain. But it does nothing. I waited for 4 hours and still nothing. I tried to advance it manually but still nothing. It will wash but not drain or spin. What could be wrong?
Old 12-05-04, 12:03 PM
majakdragon's Avatar
There are a lot of things that could keep the washer from spinning.
Do you hear any noises when it gets to the spin cycle? This could be due to something jamming the spin basket. drive fingers broken,transmission defective or worn out,frozen brake. The lid switch could also be defective. Washers won't spin with the lid open.
This could also be due to a faulty timer.
All of these things can be repaired by the DIY'er.
Chasing down the problem can be a real pain.
Even clothing that has escapsed out of the drum and became wedged.
Good luck and post back
Old 12-05-04, 12:11 PM
jackman1
Is there a belt or pully that could broken? if so how can I get access to it?
Old 12-05-04, 12:18 PM
If it were a belt or pulley the washer would not operate to wash.
here is a link that may help you troubleshoot your washer.
http://www.applianceaid.com/repair-help.html
Old 12-05-04, 12:37 PM
jackman1
that link took to a toilet repair job
Old 12-06-04, 10:00 PM
nomind's Avatar
Location: langley, in sunny fraser valley, bc , near vancouver
If this is a belt drive (I think it is) model, check the wig-wag. This is a bar with two solenoids sitting on top of the transmission. The solenoids operate two cam bars that work the agitator and the spin cam. If the spin cam solenoid is faulty the machine will not spin. Each solenoid has two wires, remove them and test for ohms. Should be 500-700 , if you read a short or open, the solenoid is shot. In most models you have to replace the entire bar with both solenoids. Another possible frequent fault is a faulty door switch or loose wires to it. Check these items and let us know it went.
Old 12-07-04, 05:18 AM
Not sure what happened but I just copy and pasted that link and it is Appliance link. Please try it again.
