washer won't spin in any cycle
I have a Whirlpool Electric Thin Twin washer/dryer model LTE6234DQ2 that will not spin in any of the wash cycles. Water will drain normally and then the cycle stops.I have already replaced the timer.You can hear a faint hum coming from the washer. It must be manually moved to spin to finish the wash. Any hints ???.
Thanks,
Bob
Thanks,
Bob
Hi Bob,
- you haven't made it very clear. If you have to manually advance the TIMER to go onto spincycle then there is apparently still a problem with the timer. Are you sure all wires are on the correct terminals ?
Do it Right - Do it once.
hi Bob,
- if it goes into 'spin' when you advance the timer, then the spin solenoid is not the problem. As I originally understood the question, the timer is stopping after the 'drain' cycle. Have I got the wrong impression?
If you just leave the timer after the 'drain' cycle, does the timer continue to rotate or not?
You are correct Sir. It stops after the drain cycle on any of the wash settings i.e. normal, delicate, etc..If I leave it after the drain cycle I can just hear a hum from somewhere inside the washer.Can this be a bad timer possibly from Whirlpool I had purchased??
Thanks so much for any help !!!
Bob
Bob
