Whirlpool combo washer/dryer won't spin
I have a Whirlpool Electric Thin Twin washer/dryer model LTE6234DQ2 that will not go to "spin" in any of the wash cycles. Water will drain normally and then the timer stops.I can then hear a faint hum coming from the washing machine.I have to manually move the knob to spin to complete the rest of the wash cycle.I have already replaced the timer with the replacement Whirlpool part.Is there any relays etc.. that have to be energized for the timer to continue to move??
Thanks,
Bob
Thanks,
Bob
Hi Bob,
- I'm not familiar with that model, but it sounds as if there's a water level switch or sensor that's not re-setting properly. Hope that's some help for you. I wll try to find out more.
Do it Right -Do it once.
