Jenn Air Oven Control Panel Keeps Failing
I have a Jenn Air W276 oven/microwave combo. For the third time in the 6 years I've been in this house it started beeping and throwing an error code of F1 (I think it showed F0 for a little while, but it's F1 now). The last 2 times I replaced the control panel (touch panel) and it's worked fine for a while. I ran through the test again (turn off power, unplug ribbon cable, beeping/error stops) and it looks like it's the control panel again.
Before I drop $225+ for another one, is there anything else that could be happening that could cause this error? Or something that could cause this part to fail again?
At some point, it's not worth it to keep fixing it. I don't know when that is, but at $250 a pop, a new oven/microwave isn't that far away!
Thanks for any help you can give me!
-Steve
-Steve
Hi sungar,
-Sorry, I know nothing about Jenn-Air microwaves. The repitition of this problem definitely sounds like something you should take up with Jenn-Air Service directly. Again, sorry I can't be of more help.
Do it Right - Do it once.
Originally Posted by nomind
Hi sungar,
Sorry - I don't think my post was clear. It's the control panel for the oven part of the unit that keeps failing, if that helps.
I'll also try Jenn-Air directly to see if they have any ideas.
Thanks,
-Steve
