Kenmore model #110.44936202
Old 02-15-05, 02:26 PM
uncletodd2000
i am having trouble with a kenmore model number 110.44936202 front load washer. i need to replace the boot and also a pump problem. i can diagnose the pump ok myself. but in order to replace the boot i need to remove the front of the washer. i have removed the bottom panel and the washer door as well. i have also removed the two screws at the bottom of the door frame or fron panel but cannott access the top screws with the control panel in place. how to remove the control panel. removed the only visibal screw but what else? also are there any manuals for this model washer? diagrams? i am desperate for assistance. any help will be greatly appreciated.
thank you,
todd
Old 02-16-05, 12:14 PM
nomind's Avatar
Location: langley, in sunny fraser valley, bc , near vancouver
Hi todd,
- they try to make these tricky, - flip off the end capson the console and you'll find a screw at the bottom of each end. this allows the console to hinge upwards, exposing the clips for the cabinet.
Do it Right - Do it once.
