No Water to Icemaker
Old 02-20-05, 06:47 PM
R
I cannot seem to get water to the icemaker.
I check and cleaned the little filter in the valve.
I checked the solenoid with a meter and it appears to be OK.
What now? I didn't though check to see if there is voltage to the valve though. If there is, then what should I look for next?
Thanks
Old 02-21-05, 10:43 PM
nomind's Avatar
Location: langley, in sunny fraser valley, bc , near vancouver
Hi ridiculi,
-I would first remove the input water pipe and check for adequate supply. The needle valve in the pipe it comes from often plugs up.
Do it Right - Do it once.
Old 02-23-05, 05:05 PM
R
Say, can the needle valve be replaced or is that not a good idea using the same hole.
Thanks
Old 02-23-05, 05:22 PM
Ed Imeduc's Avatar
Wink
Check for water to the solenoid like nomind said is so ok. But most of the time its the solenoid. It just cheap" ha "till you buy it. Most of the time its the same one on the washers hunidifiers and ice makers. Its best to get a new one if thats it. They build up with lime and calcium on and around the piston shaft.
They also have them as two together for the ice and the water. Like me. I just had to get a new one for just the ice only one is bad . But oh know had to pay for and get the double one for ice and water. Its the only one that will fit there now
ED
Old 02-23-05, 06:38 PM
R
It's not the solenoid. i tested it with a voltmeter and its ok. I also tested it manually by applying 110 to it, hooked a line to it and it opened and water flowed out.
Now I checked voltage of the leads to the solenoid and it wasn't 110. Very low so maybe the switch?
Still, can I rplace an old needle valve with a new one(essentially using same hole) or must I just put the new one in a new location. Probably better to install a real valve though.
Old 02-24-05, 03:13 PM
Ed Imeduc's Avatar
Wink
If you know how to solder Id for sure tap in a T and put the valve in the pipe. Saddles valves are just a mess some times. Check the wire schermatic for the switch
ED
Old 02-24-05, 09:49 PM
nomind's Avatar
Hi ridiculi,
- as Ed says, saddle valves are a mess. -But you don't need to solder. There are dissimilar compression Tee fittings available. ie, 3/8-3/8-1/4, which should do it. (The modern comp. fittings with inserts fit both solid and flexible pipe) Cut out the hole and fit comp Tee there. Try HD or any good plumbing store
