Please someone help belt wont tighten
Old 02-21-05, 10:31 AM
jbanaszek
I have an older GE electric dryer ( yes its old but works good still) the belt broke on it and i went to lwes to get a replacement. they had a belt that fits 97% of all dryers i took my old one down and the ribs and length everything matched they looked identical. well i installed it and it is so loose??
i took pics because there is no other pullies to go around other then these 2
its medl number DDE 7500 VA LFA
here is how much slack i have left
Old 02-21-05, 10:35 AM
jbanaszek
http://img.photobucket.com/albums/v6...natik/belt.jpg
here is the link since i cant attach pics
Old 04-06-05, 04:10 PM
2xcess
I had the same problem on a Hotpoint. Belt broke and wasn't sure of alignment. Pull the idler pulley in the direction where it has the most tension, past the motor pulley in my case, and try to feed it on the pulleys then.
