Whirlpool fridge won't dispense water
Old 02-23-05, 07:58 AM
K
Have a Whirpool model GD25DFXFW01 that will not dispense water.
You push the 'thingy' and you hear a slight hum and that's it. The filter is a couple of months old and the light indicates that it is OK.
This model was made in 1999.
Thanks for any help and/or suggestions...
Old 02-23-05, 10:12 AM
nomind's Avatar
Location: langley, in sunny fraser valley, bc , near vancouver
Hi Klute,
- first, check at the incoming pipe to make sure good water pressure is actually getting to the fridge. Next, check for any screens that may be plugged , and for operation of the solenoid valve.
Do it Right - Do it once.
Old 02-23-05, 10:15 AM
K
Ok
thanks.
The icemaker is working properly, so I think the pressure is OK.
I am not sure, but I think the valve is located inside the freezer, so the problem would have to be downstream of the icemaker, right?
