Fisher & paykel washer problems
Old 02-27-05, 07:04 AM
howeii
I have a Fisher & Paykel ecosmart washer. It started leaking during the rinse cycle. It finished the rinse and spin cycle and the clothes were wetter than normal. I tried to run another small load through but now it is stuck in the rinse cycle. All it seems do is recycle the water back over the clothes. If you try to advance the cycle to spin it will not empty and stays in the rinse cycle. Does anyone have diagnostic codes or a repair manual? Also is there a way to force it through a spin cycle. Any help would be greatly appreciated.
Thanks
Old 02-27-05, 03:42 PM
ez2frustrate
HI,
I have had a similar problem with a different make washing machine. It was because the water wasn't emptying from the wash room sink fast enough and the end of the discharge hose was staying submerged. This caused water to get pulled back into our machine. Hope this helps.
