electrical dryer problem
Old 03-01-05, 05:35 AM
karolyn
I have a Frigidaire dryer that runs for about 10 minutes then turns itself off. The clothes are warm, but not dry obviously. I thought it was the thermostat, so I changed the one in the front under the drum but it is still doing it. Is there another thermostat or another reason why it would do this?
Model # FDE336RES1. Thanks!
Old 03-02-05, 02:31 PM
boman's Avatar
Not real familiar with this brand, but there should be more stats. Find and check them. If good, I would then check the venting from the intake to the exhaust and out the vent pipe. Motor may be overheating and shutting down through the safety switch. Also make sure the motor is not gummed up with lint. A couple of cheap easy possibles to start with.
