Need Kenmore Washer Help - only fills!
Old 04-07-05, 11:28 AM
suztut25
I have a Kenmore Washing Machine that will only fill...it then has a slight humming noise and I believe I smell a slight burning smell.
It is Model #110.23032100 - I believe it's made by Whirlpool.
It won't agitate, won't spin. I've manually taken the water out.
It is only 2 years old. Looking at the back it is Direct Drive. I've been reading the previous posts here and elsewhere...do you think it's the motor coupler. Should I start there? Thanks.
Old 04-07-05, 04:38 PM
bambiblaster's Avatar
Received 1 Upvote on 1 Post
PROBABLY THE TIMER ... IF IT WAS THE COUPLER IT WILL STILL PUMP OUT WATER BUT NOT SPIN...
Old 04-07-05, 05:46 PM
suztut25
It WILL pump the water into the tub...but that's it.
Old 04-08-05, 06:08 PM
CHECK THE WIRE CONNECIONS AT THE MOTOR AND REMOVE THE PUMP FROM THE MOTOR AND TRY RUNNING IT... MAY BE SMALL ITEM IN THE PUMP...
