Burnt power cord
Old 04-14-05, 02:18 PM
chief96
Burnt power cord
Hello,
I came home to a burning smell which ended up being the power cord to my electric dryer. I turned off the power at the breaker and when I pulled the plug out, the plug had started to melt. Can anyone tell what would cause this to happen. My dryer is over 20 years old but I have had to replace the dryer socket a little over a year ago.
Thank you,
JM
Old 04-14-05, 04:43 PM
bambiblaster's Avatar
Received 1 Upvote on 1 Post
COULD BE A COUPLE OF THINGS.. LOOSE CONNECTION AT TERMINAL BLOCK... HEATER SHORTED TO HOUSING... OR JUST A OLD WEAK CORD..... WAS IT RUNNING WHEN YOU LEFT..???
Old 04-14-05, 05:52 PM
chief96
My wife was home all day and she said it was smelling the moment she started the dryer. She thought it was the clothes making the smell. I came home from work and after she turned the breaker off, I saw that the outlet was melted on one of the plug prongs. Well I did some voltage checks on the electric line and both sides registered 120v apiece. I am going to replace the socket which should fix the problem. On the plus side, she was home the entire time, and it gave us an excuse to buy a new washer/dryer set even though the dryer was not the cause. I hope. Thanks
JM
Old 04-14-05, 06:03 PM
ampz's Avatar
This may sound stupid... but you are going to replace the cord right? There are people that would'nt
Old 04-16-05, 05:24 AM
chief96
Actually I went and bought a new set. I am wondering about how this could have happened though. A friend told me that since the wiring to the dryer was aluminum that might have been the cause of my problems. I had replaced the outlet last year with a receptacle that had "al-cu" stamped on it. I wonder if I should replace the entire wire with one made of copper.
JM
Old 04-18-05, 04:34 PM
Chck with the guys/gals in th electic section... they would be happy to answer that...
