Amana 'fridge on pause?
Awoke this AM to find the refridgerator completely dead. Began emptying everything into coolers when my wife bumped the inside upper left of the 'fridge area... everything came back to life! Any idea what could have caused this? (house power, breaker, etc. are all fine).
Amana model TZ21Q2W
Can't trust it now so it's either fix or replace.
Thx
Amana model TZ21Q2W
Thx
Did the light work? If it did but nothing else could be your cold control, where you adjust the temp. If it does it again wiggle the temp knob to see if it starts up. If so replace control. If the light doesn't work then you probably have a wiring issue. Check your plug and outlet to ensure a good connection. In any event it sounds like it's still worth fixing.
still a mystery
Plug, outlet etc. are all fine. Didn't have any lights working. Hoped someone could tell me if there's a relay or thermal switch that could hang up and interrupt all power. It's been running fine now for the last 26 hours.
