location of dryer parts
Old 04-16-05, 08:10 PM
ashleyrivergal
Question location of dryer parts
Hello and tks so much for this site. I am having dryer problems, no heat. I have read all the other thread's and no what to look for and what not to look for. I just dont know where to look, I removed the back of my dryer and found the heating coils, they looked to be in order. but did not turn red, not getting hot. Would you please tell me, where to find all the other items, that had been metioned. please any response would be appreciated. tks
Old 04-17-05, 03:49 AM
bambiblaster's Avatar
Received 1 Upvote on 1 Post
RUNS BUT NO HEAT.... 1ST THING TO CHECK IS THERE 220 GOING TO THE MACHINE... THEN UNPLUG UNIT... CHECK HEATER FOR CONTINUITY AND AT THE TOP OF THE HEATER BOX IS A THERMAL FUSE... CHECK THAT ALSO FOR CONTINUITY...
Old 04-17-05, 07:20 AM
ashleyrivergal
Wink Where at the fuses
Tks very much Bambiblaster, for replying. Where would the fuses be located at, same place as the heater coil, just above it, my machine is a roper, res76648k02 dwjr-elec-2406028-fm54. I have taken off the top and there was a wiring diaprahm for elec, but i cant make cents out of it. I cant find my paper work that came with it. tks again
Old 04-17-05, 08:47 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Arrow Additional Information Provided
Hello: Ashley
Read the web site of the manufacturer. Link provided below. Likely to find much more additional information, pictures, etc.
Roper Appliance Home Page:
http://www.roperappliances.com
Advertisers & Sponsors Web Sites:
Appliance Parts, Pictures & Help:
http://www.PartSelect.com
Appliances Parts & Help:
http://www.pcappliancerepair.com
Kitchen Appliance Parts:
http://www.parts-depot.online.com
(The codes are not turned on in this topic. Copy and repaste the link addresses above into the browsers address bar)
Also click the google ads advertisers links.
Additional Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, downloadable repair and or owners manuals which may be available online.
Retail appliance parts dealers can also help determine what the most likely possible problem may be. They will need the make, model and serial numbers. Appliance parts dealers are an excellent source for original replacement parts and problem resolving matters. Dealers are listed in the phone book under appliances.
Be sure the electrical power to the appliance is turned off, before attempting any repairs.
Use the reply button to add additional information or ask additional questions. Doing so will automatically move or keep your question to the top of the forums list of questions.
Regards & Good Luck.
Web Site Host, Forums Monitor, Gas Appliances Topic Moderator & Multiple Forums Moderator. Natural Gas Appliance Diagnostics Technician. Utility Workers Union of America. UWUA (AFL-CIO)
Personal Safety Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
DRYER SERVICE TIP:
It's always adviseable to clean the entire exhaust venting system every 2 years. Or during any dryer maintenance, connection, servicing and or repairs.
Old 04-17-05, 09:41 AM
ashleyrivergal
Thanks for the listings
[B]thanks for the listings , I am working on getting a test meter, again you have been very helpful, have a great day!!!!
Old 04-17-05, 06:35 PM
ashleyrivergal
Question Help
Ok I bought a multimeter, checked all my connection. I have power going to and from all connections. What next, is it that my heater coil is bad, I find it hard to believe that it would burn out in a lil less than a year old, please someone give me a reply. (fustrated as all get out) but dont have the money for a real repairman.
Old 04-17-05, 06:52 PM
ashleyrivergal
Question Bought a multimeter
Hello, to whom ever is out there. I bought the meter and checked all connections, they have power to them, so would you say that now its the heater coil, I cant believe it would go bad in a little over a year. plase some advice, thanks Ashely
Old 04-18-05, 04:04 PM
On the heater box (long tube holding heater) at the top should be a thermal fuse... remove 1 wire and check it for continuiy... if good... remoe 1 wire from heater and check it also...
Old 04-18-05, 04:37 PM
ashleyrivergal
Thumbs up Hey there Bambiblaster
Hi there and tks for all your help. I bought a multi-tester and call a guy at a repair shop , he walked me thru all the testing, come to find out it was all just my breaker, it was only sending 110 to the socket, instead of 220, because the breaker was sitting uneven, therefore, not making a good connection. I switched it back and forth, and guess what, I now have a non-broken dryer, thanks for all your and this is the best site, I have seen, and informative.
have a great day!!!! ashleyrivergal
